WTB: OEM Fog Light Brackets
JeepGirl1013
Missouri
Looking for OEM brackets, brackets that will work with OEM Fog lights, or someone who can 3D print them!
If your Jeep is a 2001 then you have the OBEN lights. They changed to Hella in 03 :) Just as a reference.
I designed such brackets for my OEM fog lights (OBEN for a 99) some time ago. They fit and got the job done until one cracked due to poor layer adhesion; For temperature tolerance I printed them from ASA which has a high glass point. I plan to make another set with as sparse infill as possible then hollow them out and fill with epoxy for strength. My Jeep was my daily until I accidentally turned it into a mess of a project so I can't say these fog light brackets are high up on my priority list, but if you're open to doing some experimentation, I can print you two sets, one with maximum and one with minimum infill, for you to play with. You'll have to paint them if you want them black.
Reactions: JeepGirl1013
That would be cool! I just love the look of the original fog lights 😂
Are these brackets for the lights to mount on the bumper? I have an old set with a metal bracket on the light housing, is this what your looking for ?
Yes I have the lights and the bumper and no way to connect the two 😂
Will these brackets work for you? They are off a 99.
