Out of curiosity, I loaded the stock Rubicon data and my regeared data into the calculator at the Grimm Jeeper's gear ratio calculator. http://www.grimmjeeper.com/gears.html
Check the attached. My '03 Rubi with 33s and 4.56 gears is almost exactly the same as the stock Rubi. BTW, I have a NV3550 transmission.
Next trip out I'm going to check that against actual RPMs, MPH, etc.
IMHO, this confirms @Jerry Bransford assertion that 4.56 is the right ratio for 33" tire size and a 5-speed. Unless of course, you are into serious rock crawling. Alas, I'm a mere mortal and quite happy with moderate wheeling.
