So I have an issue that is pretty weird to me. When I have the headlights on and, go from high to low, the engine will shut off for a second and, when I turn the headlights off, it will do the same thing. Engine shuts off for just a second. I started digging around and checking everything that could think of and came up with nothing. I started feeling like it was in the headlight switch so I replaced it. It actually did seem to take care of the issue but, it started doing it again but, it’s more intermittent. So, I was running the engine while going back and forth through the functions, high, low and off while whacking on the bottom of the steering column cover and it seems like I could almost make it malfunction.
I’ve checked every plug and connector for corrosion and tight fit. So I’m to the point of asking if anyone has experienced this issue.
