Here are the instructions for a Scout 44 floater. Good news is that the majority of floater kits use the same bearings and seals:
Outer bearing set A35 lm501310/lm501349
Inner bearing set A47 lm102910/lm102949
Seal CR22353 and try to stick with CR if you can.
These are the same bearings and seal the Warn 5.5 front hub conversion uses as well.
The common Dana 44 wheel hub used:
Inner bearing set A37 lm603011/lm603049
Seal National 4250
Hopefully this gets you in the ballpark of what you have in there.
