For this episode of "How do I get rid of the steering wheel shake in my TJ" we have a 2002, 4.0L with 32RH auto, a new lift with 2" Pro Comp springs and Rancho RS5000X shocks and Daystar .75" spacers in front, 31x10.50-15 tires at 26 psi, Canyon rims with no dents. Sometimes it shakes sometimes it doesn't; I cannot find a pattern or reason but it is more often than not. When it shakes it starts at 45 mph and fades between 55 and 60. If I get a long, flat, straight stretch of road (common in FL) it can even start and stop without change in speed or direction. Bumps in the road do not affect it.
So far I have...
Balanced the wheels - no change
Completed an alignment - no change
1" TC drop - no change
Removed TC drop - no change
Checked for play in steering components - couldn't find any but admit my lack of experience
Dry tested steering - no noticeable play in track bar
Rotated tires - no change
Re-balanced the wheels - no change
Tightened the lower front track bar bolt - no change
A diesel mechanic friend of mine insists that there is slop in my track bar and suggests that I get a new one.
What are the suggestions of this group?
So far I have...
