That's good insight, and something I don't think I've read about your build before. I actually do want to outboard. I'm not afraid of the expense of the shocks. I'm just waiting until I'm "done" experimenting with tire size and ride height. That, and I'm not sure I want to put that kind of time into this particular frame... I fear a replacement is in my future.My mid arm went on almost a year before I did the rear outboard. There were no other changes at that time. Again the differences on pavement were miniscule. I daily drove this setup all around Colorado with about a 3.5" spring lift, the old style OME shocks and an Antirock.
If my Jeep was somehow unusually unstable after, then it was unusually unstable before. Which it wasn't.
I knew after the rear outboard and the tune I happened upon that there was something special there that I needed to continue to pursue. I won't go into the full details, except that I began to recognize the extent that shocks were able to define the ride quality and control the movements of the vehicle. Done well, it is very dramatic. And now that the fronts are done and all four corners have the updated tune that the rears came to me with, all my predictions and expectations have been exceeded.
I have no doubt that the short arm geo correction kit has real and noticable improvements over stock, especially where roll is concerned. But reducing roll is also achievable though shocks (and sway bars) and with them, a broader range of handling improvements that cannot be gained through geometry alone.
Those KYBs look interesting though... I'll have to plug them into my spreadsheet and see how they look on paper. I do have a set of the SA correction brackets sitting on my workbench, waiting for their time. I don't ever see myself needing a mid arm suspension, so the geo correction on short arms made sense to me. I do get wheel hop, at 2" of spring lift. Enough that I have to back off on loose, slippery climbs. That's no fun, and we have lots of loose, slippery climbs here. Maybe the midarm would work for me too (I don't think it's an either / or discussion) but I also don't see the need to run that much articulation here.
