I installed the Savvy transfer case shifter last night and works great
ordered a new soft top since the zippers on the used one I got from a friend basically fell apart. I'm only planning on using it to cover up if it rains as I have no garage, so got a cheap one.
Somewhat depressing as it had no oil issues before and it was a sudden bad leak a week after changing the oil.
Which one did you get? I got the cheaper Pavement Ends line one by BesTop and it's held up well so far, but I have had it up 100% of the time since I got it since they are a PITA to snap the latches on.
That sucks. There's nothing like doing routine maintenance and then having it all undone by a problem. Sounds like you are on it for the fix though.
Finished the install of my amp! Now to order the powered sub.
I actually have that same amp running 4 - 6x9 JBLs and aM 350 running a 10 JL sub in my system in my Toyota truck. I love them. Can't beat them for the cost.Nice! I just ordered that amp as well. Great bang for buck with a lot of power for speakers. Have you used your speakers with it yet?
That’s why they’re inside outyou roll them down onto the top half of the seat
Damn, I did not know they were made in aluminum. I have the HF steel version. Its good for what it is intended for, light duty use.This one is a aluminum folding trailer from northern tool that was pretty much new I picked up off craigslist. Harbor freight sells a steel folding one for like $250. You can google kayak trailer harbor freight and get many ideas. Basically a plywood deck, some 2x4s and 1x6s, and 1.5” pvc tubing (added 1’ aluminum box tube inside for more rigidity and strength). Put my kayak J carriers on it and it was done. Optional but I replaced the ply tires with a better set of rubber ones and added a trailer jack. All in all probably spent around $700. I’m pleased with it. And best part is I can take it apart and fold it up in the winter months.
In my day it was "Boss!"You're not getting old, maybe you've just been too busy. Not that I'm young enough to use it but I think "sick" has been in use like that for about 20 years.
And it’s done! 2 coats of bed liner just about finished off the can. I couldn’t do much with the little bit left so I hit a couple areas again with a heavy coat. The darker spots are where it was still tacky. I left it at the shop for the night and tomorrow I’ll grab some fresh hardware and start the install![]()
They’ll loosen up over time.I thought that at first, but the instructions started with them right side out, so I figured I would do what was on them.They are hard to work with — the material is like the soft top almost. Need to put them in the sun.
