Not seeking for help, I’m just showing off my blow motor. No worries the Jeep will live another day it’s getting a new (to me) motor put in soon.
Well if you remember back about 3 weeks ago I posted on the forum about rod knock " https://wranglertjforum.com/threads/is-this-rod-knock.30833/#post-497894 " and I was about 160 miles away from home. Guess its safe to say its not rod knockDamn! Any idea how this happened?
currently swapping in an 01' cherokee 4.0 will post pics.Ouch. Keep us posted on the progress.
My mechanic says that the aluminum piston probably got fatigue since aluminum gets porous and less dense over time from stress and will lead to cracking. Said that aluminum is weird, that some aluminum pistons can last forever and some can last not so long.That's right, now I remember!
Definitely not rod knock at all. Makes me wonder how this happened though, as this doesn't typically happen to 4.0s.
Have you thought about just cleaning it up and running it for awhile so you can find where the problem is?
Customer service *did you try turning it on and off *Huh? The problem is he only has half a piston
Did I miss something?
I saw an engine do that... after checking the Fuel injectors we found the one that was in that cylinder, was not closing and was putting raw few into the cylinder constantly. We saw a lower MPG a few days before the failure and then the piston failed. It looked like skirt failure caused by the rings seizing in the cylinder. Also, the oil was a bit thinner than usual. any of this match-up to your failure?Not seeking for help, I’m just showing off my blow motor. No worries the Jeep will live another day it’s getting a new (to me) motor put in soon. View attachment 142953View attachment 142954
Actually I didn’t have any of those symptoms, my oil looked good. I got about 17 mph highway with 33” tires. The only thing that was wrong was after a long drive I heard a ticking soundI saw an engine do that... after checking the Fuel injectors we found the one that was in that cylinder, was not closing and was putting raw few into the cylinder constantly. We saw a lower MPG a few days before the failure and then the piston failed. It looked like skirt failure caused by the rings seizing in the cylinder. Also, the oil was a bit thinner than usual. any of this match-up to your failure?
