Absolutely! How could I possibly forget the ridiculous OPDA. That should have been the first on my list.2 inch lift
Tummy tuck
External voltage regulator
External TCM (‘05-‘06)
Better OPDA design (‘05-‘06)
But overall, I love mine. : )
Tummy tuck
With 28 or 29 inch tires, I cant remember what the factory equipped them with. Heck even 30 inch tires, the Dana 60 center section would be a ground clearance issue. More so than the, "shovel," of a skid plate that comes from the factory.It be nice to have Dana 60s under them too.
Wait, what?I would ask the engineers to use metric or SAE bolts throughout the vehicle. Not both.
Damn. That’s an interesting angle.I bet if you asked CJ owners around 1985 it would like this:
* same engine, fuel injected
* wider wheelbase
* shift on the fly 4wd
* a real dash
* a/c
* a quieter/drier /warmer top
* carpet
* a bigger console
* front disc brakes
* coil spring front end
* better ride / handling
* swing out tailgate
* better ergonomics
* a sound bar
Sounds familiar? That’s a TJ .
Eventually , life gives us most everything...just not all at once.
E-brake on the driver's side, so I'm not always grabbing the water bottle...
It's not just Jeep. GM and Ford did the same thing in that era, which basically makes it an American thing. I assume it's the nature of the supply chain, with global parts suppliers' availability and pricing being more important than consistency.
So it seems about half want an updated version with modern electronics and a bigger machine and about half want a more retro version with a more basic drivetrain and keeping size narrow and shorter. I wonder how the age difference plays out in all this.
Do the old duffs want the older tec with simple window cranks and the youngbloods want the bluetooth headrests and laser beam fog lights? Or the other way around?
My father still complains about everything going to crap when pneumatic tires replaced horseshoes!
* wider wheelbase
* a real dash
* a/c
* carpet
* a bigger console
* front disc brakes
* better ergonomics
* a sound bar
I'm with you 100 percent on that displacement , man that would be great .Having come out of the CJ5 world to my LJ, I can see a lot of this. Some of the list were on my last CJ5 (1980) from the factory, like the disc front brakes and while mine didn't have them, a/c and carpet were options on the more upscale ones. But there's a few things I do miss about the old CJ5s.
There's times I miss the drop down tailgate. I'd suggest a swing out spare tire holder separate from the tailgate, but a tailgate like some of the early 70s Ford station wagons had that could either open as a door or drop like a regular tailgate. Way back when I've owned a couple of those old Gran Torino wagons and that was one of the features I loved about them.
Someone mentioned a new straight six engine. If I was designing it, in the 300 ci range, rugged cast iron block and head, cross flow head for better flow, either overhead cam like the old Jeep Tornado engine, but if OHV, side covers to get to the lifters easier like on a Chevy six. The idea of pulling the head to replace the lifters just doesn't appeal to me.
Some of these redesigns, wants, dreams are simply that, dreams. I am not an engineer, take my changes with a grain of salt. But please critic my list.
The factory Hellcat Dodges have factory options/specs that I would have never guessed would come from a factory auto manufacturer. Because the hellcats are designed by actual automotive engineers working together, they work.
Modern all aluminum straight 6, maintains the big tq numbers from straight 6's and ups the HP with modern engine tech/design.
OR
Modern straight 6 with a turbo. For the EPA folks.
Or
Something similar to the first gen Chevy Colorado; A small 5.3 V8. This would likely fix any lack of power when mated with an overdrive transmission.The overdrive trans would also allow great gas milage not seen in the early 2000 trucks/suv's with V8's.
I don't like the TJ/LJ body lines when high lined, the front end just looks off. This could likely be fixed with a taller hood and cowl if high lined like the JK's and JL's from design.
Never thought much about that. I guess I'm on the fence with that too. But, for the sake of maintaining it's appearance, I think I would vote to keep them there.To move the turn signals from the fenders or leave them in the fenders?....I'm on the fence on that one.
Absolutely! I recently put one of the factory fit, drop-in style android headunits in mine. Never been happier with any other headunit purchases. Although, in this case, I'd vote to make it a little taller and have smaller buttons so that it could maybe house 7" screen.Radio is touchscreen with Bluetooth and wi-fi.
Good call! Without that, you know even with a remastered model, "they" would most likely feel like new colors are needed. Keep with the originals. I don't recall any color of their time that was terrible.Any exterior color from 97-2006 is optional.
Great reply. I agree with you. Unfortunately it will never happen. However, any one of us can make the changes that we believe are for the best for our TJ's/LJ's.Dang, man. Lot's of good ideas. As I said before, I'm no gear head, so I don't know what the downsides would be if any), but I like this idea. With the power being produced with 6 and even 4 cylinder engines these days, along with 8 cylinder engines higher gas mileage, it would be great to have more power and greatly increase the fuel economy at the same time.
I completely agree. That's the only negative I have for them. I think it's the length of them. They would need to be shortened a little, so that they don't protrude from the front as much as the AEV Hi-Line fenders. That would involve a redesign of the fender's shape along the front, but it would look so much better and allow 33's to fit without modifications.
Oh, and I remembered another quirky thing. Get rid of the joined area between the back of the fender and the front of the doors. I guess it's too early for TJs, but I've seen many CJs with cracking paint and underlying rust along that joint. I assume they kept it for ease of fabrication and/or aesthetics. Anyone know the reasoning?
560 lbs.Out of curiosity anyone know how much the Ford 300 I6 weighs? And it's length? That might be a decent upgrade. They put out plenty of torque. Much better engine than the 302 V8 in the older trucks.
Let’s be honest, compared to modern engines, old engines suck. The technology, research, and design today is simply amazing.Out of curiosity anyone know how much the Ford 300 I6 weighs? And it's length? That might be a decent upgrade. They put out plenty of torque. Much better engine than the 302 V8 in the older trucks.
I would think it would have to be plastic. Its a federal mandate on all new cars. It increases the chance of survival for pedestrians who are struck by vehicles.Wish they had done this.... 1997 Dakar Concept
amazing how the bumper looks kinda JL.
Let’s discuss. The Jeep factory 4.0 makes its peak tq at what RPM? And what does it make at 2000 RPM? What aboutV8s do make more power with a lighter weight. But usually at a higher engine speed. The inline sixes make their torque at lower rpm which is more beneficial when off road.
