After going topless for a week, I mounted my soft top frame, in preparation to install my new soft top. Hard top stored in garage on a dolly.
Looks great
Looks great
THATS IT.![]()
Looks good!
That is one smart looking tailgate table (and the 0.2 model that @DrDmoney tweaked ) great addition.Thank you @DrDmoney for making this mod possible. I didn't have a 50lbs weight so I used a 5 gallon container of used oil and @tomtaylz mangled rear bumper. View attachment 97021View attachment 97023View attachment 97022
I was very lucky. Since he found out he could make his bigger this one was basically plug and play.That is one smart looking tailgate table (and the 0.2 model that @DrDmoney tweaked ) great addition.
Got the new hinges next day air!Update- just talked to Quadratec ...they are shipping out the replacement, "next day air"
we shall see how it goes
If you still have the ignition cylinder try some teflon lubricant like Tri-Flow in it to see if that helps. Number one reason for locks to fail is lack of lubrication. If it does work then you have a spare cylinder.Key stopped turning in the ignition switch, couldn't start the Jeep all of a sudden. Realized that I could hit it and the key would turn. So, I got the ignition lock ordered over night and replaced it today. Good as new!
Dr Dmoney, Are you selling these?Thank you @DrDmoney for making this mod possible. I didn't have a 50lbs weight so I used a 5 gallon container of used oil and @tomtaylz mangled rear bumper. View attachment 97022
i bet a lot faster than hawaii . i dont even have a 4x4 shop anywhere near. napa is an hour 1 waygot my new Rancho shocks it a few days ago, and finally got a day
when it could put it in without getting soaked.
I got 3 of the 4 shocks installed. when I went to install the 4th shock,
I found that the pressure wasn't right.
So back to Northridge 4x4 ... we will see how long it takes to get the replacement here...
