TIPs for JL/JT Axle Swap: I've decided to modify the original post to include questions and answers as I work through everything.
Current questions:
1) Which Axles?
Mine: Front - 2023 Max Tow JT (Price was right). Dana 44 (M210), same width (67.9") as the Rubi but missing the locker.
Rear - 2022 Rubicon Dana 44 (M220) with OEM 4:88 gears and the OEM electric locker.
Gearing?: Mine 4:88 when I match the front to the back.
Most desired: 2024+ Gen 3 Rubicon 392 Axles. Thicker walled, stronger housing, and the rear is a full float, geared 4:88 from factory.
2) Control Arms?
Mine: Genright Legend Double Triangulated 4-Link rear / 3-Link Front.
Options:
TJ OEM - I wouldn't.
Mid Arm - Lots of options! (Let me know what you did pros / cons!)
Disadvantage: Lower frame bracket locations.
Long Arm - Lots of options! (Let me know what you did pros / cons!)
*Single Triangulated
*Double Triangulated
Side Option that is currently working well on my TJ with stock TJR axles is to use JL/JT oem control arms, works very well like a mid arm. You will need to move the frame brackets but to me was well worth the work.
3) Axle Truss? Yes or No?
Mine - Yes - Artec JL/JT to TJ Swap kit
- Lots of other options! (Let me know what you did pros / cons!)
12.09.25 Note: Discovered the Artec JL to TJ swap truss puts the coil perch in the stock TJ location so we lose the 1-1/2" stretch with their kit as is. I called their tech line was told I was the first person to request a bracket with the coil perch centered on the axle. (to me it's a no brainer free 1-1/2" front stretch).
I can order their "Ultimate Coil Bracket" to recenter it but not guaranteed to fit with the kit. I'll post what I decide later.
4) FAD, keep or delete?
Mine: I'm keeping since I'm going to RCV's, get the on road benefits (vibration mitigation, MPG's) and I'm not seeing reports of failures.
5) Coils and shocks / Coilovers?
6) Steering Components?
Tie Rod: Mine- Steer Smarts
Drag Link:
Trackbar:
7) Rear Brakes?
Disc brake lines - how?
E-brake cables - how?
8) Knuckles?
9) Axle shafts? One piece or two? RCVs?
Mine: RCV's keeping the FAD.
10) Drive Shafts?
Mine: Currently Adams 1350's. I will send them back to Adam's for any needed adjustments.
11) Ball joints? Deletes?
12) Wheels?
Mine: Current plan is JLR take offs.
13) Tires?
Mine: 38" NItto Trail Graps
14) Lockers? Stock or After-market?
Mine: OEM, will need to drill the front diff to fit connector for OEM locker I picked up on FB Market.
I am sure there will be lots more questions as I go.
Also... if you know of any tips or "watch out for"s... please share!
Current questions:
1) Which Axles?
2) Control Arms?
Options:
Drag Link:
Trackbar:
7) Rear Brakes?
8) Knuckles?
10) Drive Shafts?
12) Wheels?
13) Tires?
