Any ideas on a random cutting out situation? Check engine light flashes when it cuts out, but never stores code, scanner disconnects do unable to watch data to see anything. Tech and speedometer jump during event also. Seems to be load related, but will get worse as it gets warmer, or after a longer drive
Stuff I’ve done =
•New battery cables
•New crankshaft position sensor (does the same thing with a used oem one, used aftermarket, and new aftermarket)
•New distributor pickup
•New coil
•Verified fuel pressure during event
•Verified voltage out of fuse #11 during event
•Cleaned grounding points
•Bypsssed ADS relay, no change
It’s a 1997 wrangler 4.0 5 speed, bought it in January, it had a hard start issue when I bought it, put a flagship one ecu in it. That fixed it at that time, this recently started. I have also purchased and installed a WranglerFix pcm, no change.
Stuff I’ve done =
•New battery cables
•New coil
