Is this normal, My steering was a bit loose (sloppy) and Tie rod ends/center Link were all original. (125k mi) I just replaced with all new moog parts with the heavy duty tie rod ends. It took the slop completely out of my front end. Toe-in is set to 1/16” but now but it seems when I hit bumps It has more of a pull on the steering wheel. I did replace the track bar two months ago. The Jeep has a 4 inch lift the track bar I put in was identical to the one I took out, Non adjustable. I ran the Jeep up to 70 miles an hour. There’s absolutely no death wobble.
