After flop maintenance?
inkedrose
washed up superhero
Arvada, Colorado
Made a bad line choice yesterday and ended up on my side. Learned from the Moab guys to kill it, pulled plugs and blew it out. Did all that, smoked like crazy for awhile. Finished trail and drove 2 hours home. Everything sounds good. Don't have any extra lights or codes. What's else do I need to be doing maintenance wise? Anything in particular I need to be following up on?
Walked away with minimal damage and no scratches on me. Thanks @lBasket and @NDSpeed for the help flipping her up again
If everything sounds good I would just go through and clean up any fluids that leaked in the engine bay and check your battery and cables and make sure the battery didn’t shift over too close to the fender. Check your axle vent tubes to see if there was diff fluid leakage. Check your transmission fluid level.
didn't even consider transmission. Engine bay is todays project tried to wipe it up as well as I could on trail
Reactions: JMT and bbaldwin237
Have you checked if your door still closes on that side? I didn't notice that on the trail
No… I’ll wait until winter to find out. No point being bummed all summer. Crossed my mind if the cage shifted too… will hard top fit back on? I’m saying everything is good to go for now 🤣
