https://www.amazon.com/dp/B00FZP1LT4?tag=wranglerorg-20
Best price I’ve seen for one. I paid $130 four years ago.
$68 at rock auto
Did you see the Amazon reviews? Seems many pumps arrive with broken impellers and dented housings due to not being packaged properly. Sounds like the pumps are in a thin box with no internal padding, just as you would find on a parts counter shelf, and NOT intended to be shipped.
Mine arrived today. Gasket was a little bent, but not badly.
Looked inside the water pump and pulled out two strips of metal, thin and bent, almost like pencil shavings. Can't see where they came off of anything inside. Impeller turns freely. Any ideas?
Looked inside the water pump and pulled out two strips of metal, thin and bent, almost like pencil shavings. Can't see where they came off of anything inside. Impeller turns freely. Any ideas? Smaller one looks like it could have come from the threading process.
I'll use a Fel-Pro gasket when I eventually do the install.
Looks like metal from the machining process. The spiral metal is what you’d expect to see coming off a lathe. Dang, you’d think that would be removed in a cleaning process
Instead of OEM? Should I do the same?
Ace Ventura delivered mine a couple days ago. Gasket folded up as well. Box beat to hell, but pump unscathed. View attachment 618640
Crazy the price drop. I think it was $200-$250 from the dealership last year and they now have them at $118 from the mopar dealer down the street. That’s 68382492AA but all the same. Wander if the supplier changed resulting in the poor Quality Control. Maybe I’ll grab one up to have on the shelf.
Showed up yesterday. Box wasn't to beat up. Gasket is flat and no machining chips that I can see. Another part to add to the pile of parts.
