If I upgrade to 33's will they fit on the stock spare tire carrier in the back or will I need to get a new one to accomodate the 33's
Yes, but be careful that your rubber snubbers are pushing firmly against the tire or you'll live to regret it.
The answer is, "It depends..."
The stock rear bumper may interfere with a 33 if you don't have a body lift. Also, what you need to do to properly support the tire with snubbers depends on the offset of the wheel the tire is on and the width of the tire (33x10.50, 33x12.50, 2885/75R16, etc.).
Interesting. The tires on my 2000 TJ were changed to 31x10.5R15's from the original 30x9.5R15's by a previous owner. However, they left the original sized spare on the tire carrier, which is kinda weird. But I notice this spare is at least an inch away from the snubbers so there's definitely no firm aren't pushing going on. You seem to indicate this is a problem. Should I be concerned?
I welded up a tailgate tire carrier so that the 35" tire rests on the snubbers with no spacers and more importantly the tire rests on the bumper. Installed 12ys ago and the hinges are fine.
Well heck the High Lift helps hold it up too......![]()
You should be concerned if you hit any speed bumps or unpaved roads. Without the snubbers contacting the rubber tire very firmly the tire weight will bounce around on the tailgate and eventually destroy the entire tailgate.
Nothing is likely to happen if you stay on-road only, but if you ever go off-road (or even just bumpy, unpaved roads) you're asking for trouble.
A 33" tire will work on a factory tire carrier, but it will not clear the stock rear bumper.
I have a 265 75R/16 tire on mine (almost 32") and it touches the rear bumper. Any bigger, and the bumper would stop the tailgate from closing.
