Alright, I have a misfire. No one has been able to find it, it's a ghost, and it's so slight it's almost a ghost as well.
So, tiny misfire, but consistent. You can hear it every second, or every couple of seconds, or several times a second. There's no predicting. It happens if it's under load, it happens at idle. The only, only time it doesn't miss is during the first 10 to 20 seconds after starting. It'll sound just fine until it's slightly warm and the miss comes right back. The only thing that impacts it is a vacuum leak which makes it louder.
It's never thrown a misfire code of any kind.
I've had three Jeep mechanics look at it, one of which rebuilds 4.0s regularly, and no one has an idea. The rebuilder said from the sound of it he thinks it's electronic, but doesn't know where.
So far I've replaced every sensor of which I can think. O2 sensors, TPS, CPS, MAP (I switched back to the Mopar as it had no impact), all Mopar. I've replaced the throttle body as the old one leaked. I've smoked every location on this Jeep and plugged every leak. Distributor replaced, spark plugs, wires, cap, rotor. I've replaced the computer. No exhaust leaks before the muffler. Cooling system flushed with Prestone and Thermocure, new radiator, water pump, holds pressure. No exhaust leaks in the cooling system. Compression test showed all within 10% except one which was slightly lower. Gas mileage is good, around 15.5 mpg if there are no vacuum issues.
When I plugged the vacuum canister line today the miss got a little quieter, so I'm ordering a universal vacuum canister.
Does anyone have any ideas?
Yes, I've posted in the past, but I've performed more repairs/upgrades in the past several months and wanted a clean-slate start.
