Aside from the feds. What are the smog ramifications in SC?
I don't think SC has annual inspections, at least not emissions. I was referencing Fed requirements and the likely insurance issues.
what im confused about is people who say that all i would need to do is install the appropriate hardware for things like a new transmission and a carb kit, which is a lot of stuff but its small things (not saying with small importance) like driveshafts, throttle linkages, modifying the fuel tank, things like that. and then you say id basically need to start from scratch with a clean frame.You would basically need to gut your TJ, and start over with a roller (chassis and body), nothing else. If this is a wrecked, rusted out mud bogger never to see the road
again, then sure, cut and splice away. But why would you do that to a good Jeep, which I assume is the Jeep in your avatar? That's not even touching on the legal aspects.
the main goal is to get rid of the computers, i dislike the idea that my car needs computers. its a personal preference that barely anyone understands, I cant logic my way out of it.You have any experience tuning a carb? Swapping out jets? Checking vacuum? Power valve? Adjusting the float?
I love my 97 because it has just enough computer to make my life easy...that includes automatically adjusting the fuel/air mixture in all conditions and altitudes...to telling me enough information to troubleshoot and narrow down my problem to something manageable...even trail repairable.
I had a 69 Chevy K20. 292 straight six and a Rochester monojet. I spent more time with that carb than I did on anything else on that truck. Got rid of is a few years before LS swaps got easy. Otherwise I would have pulled that engine and dropped in a 6.2.
And with @Wranglerfix and @Flyin' Ryan Performance you can do a lot with that stock PCM.
If you want more power you can stroke it to a 4.7. You could add a turbo or supercharger. There are 5.2 and 5.9 swaps - V-8 power from a Durango or Ram truck. You could LS swap it... Terminator X from Holley is expensive but easy and HP Tuners would let you reprogram a stock GM computer.
Every one of these is a tried and true, proven recipe for making a TJ better.
I think the only time I'd consider carb swapping my Jeep would be after a nuclear war and EMP wiped out the planet and by some remote chance my PCM didn't work...and I believe it was the Navy that tested our Jeeps and discouted this possibility. But then if have zero resources to figure it out and about two months before all the shit ethanol gas went bad.
again this thread isnt about whether i should decomputerize my jeep or not, its about the best way to go about doing it.
Awesome thanks
Like I said im no expert on GM engines or powertrains, I didn't know they made 350s w/o computers.
i just want to know [...] the best way to do it
Why not take an engine/trans/transfercase/gauges/etc out of something old without a computer and swap it in to your Jeep? Sounds like you've got the money to do it, and it seems like that'd be the best way to do it. Lots of people are looking to swap modern engines into old cars so you probably wouldn't lose that much money once you sell off the frame and body of the donor.
You might also want to figure out places that sell ethanol free gas since your engine isn't going to like modern gas very much. A marina might be your best bet. Or if you go old enough on the engine, airports still sell leaded gasoline.
Real men buy there fuel at the airport. That’s what I heard anyway.
Unfortunately everyone sucking on the pipe resulted in the generation that doesn't know how to tune carbs.![]()
Just swap the motor out of a lawn tractor. Cheap, easy, reliable. 15 HP should get around town okay. A turbo would certainly help
thats what I figured is the best option,Why not take an engine/trans/transfercase/gauges/etc out of something old without a computer and swap it in to your Jeep? Sounds like you've got the money to do it, and it seems like that'd be the best way to do it. Lots of people are looking to swap modern engines into old cars so you probably wouldn't lose that much money once you sell off the frame and body of the donor.
