The nv3550 should give me a slight advantage.This summer with my Atlas in we can race
Unless you go 5.13. Then you should barely win.
Me: 4.88x4.01x5=97.8
You 4.88x3.83x5=93.6
W/ 5.13xx3.83x5=98.2
If I was you I'd highly consider 5.13. Unless you do a lot of cruising at high speeds.
This summer with my Atlas in we can race![]()
I have an Atlas too! I’m in!
Can us Non-Atlas guys get in on this?
Since @Woodrow and @Alex01 both have 5:1 does that mean I can use my Low-low range? It's only 5.44:1 And that is @NashvilleTJ low with his crawler box engaged.
One on 40's
One on 38's
Two on 35's
Should be interesting.
Top search before the race. "How to lower your idle speed"
One on 40's
One on 38's
Two on 35's
I have a Rubicrawler, can I play?
111.45:1 in double low
Do you have a Rubi t-case or a standard NP231? Looking for your ratio of the Rubicrawler & t-case.
That is with the 231 and Rubi
...crawl ratio ... in the 100:1 range and it was fun to hope out and walk along beside.
@Alex01 is almost at 100 and that seemed totally feasible when I drove it. Now you guys have me thinking 5.13 instead of 4.88 when I regear.
I'd be around 3000rpm at 75 mph in 5th gear (0.79) with the 35s, and 5.13 gears. Not terrible and I am rarely am on the freeway.Even with your stroker motor I think you'll like 5.13's for on road driving. I know it's not the same but I've got 5.13 gears in mine.
Placed the deposit on the motor today. Scheduled to ship the 2nd week of April.
As of today my parts list consists of:
Starter motor (Mopar)
Brake Master Cylinder (Mopar)
Clutch Kit (Luk)
Motor Mounts (Anchor)
Water pump (Mopar)
Thermostat & housing (Mopar)
Fan clutch (Mopar?)
Brakes (BMB) - I've been looking at his caliper-rotors-pads kit. Any recommendations on replacement brake lines?
Fuel Pump - Is Delphi still the recommended brand for a fuel system refresh? Partial rebuild with Mopar parts?
Regear to 4.11 - This one will be dictated by finances when the time comes. Sticking to 3.73 on 31s should be good enough for now. Will want to do this regear eventually whether I jump to 33s or not.
Driveshaft U-joints - They look to be in good condition, but the way I'll be getting after it with the extra power, I'm thinking it could be a good idea to replace with new. This could also be another "don't fix it if it ain't broke" item. Would go with Spicer.
What am I missing?
Thanks
