Keep mine in the same place. Used some foam pipe insulation as cushion and strapped down to d-rings in cargo area. Easy to put in/out. Not going anywhere and out of the weather. Foam and straps cost about $20 all in.
Honestly, I don't carry mine anymore, and not because this site told me not to.
The problem I have is not everyone gets to wheel with uber experienced off roaders that have high dollar rigs with winches and lockers. Lots of people use their vehicles in lots of different ways, and get in lots of different types of situations. Who's to say what someone else needs or doesn't need. That $100 farm jack is exactly the right tool if that's all they have.
I don't care if folks wanna run the jack but wondering if someone creative might come up with a mount for it on an angry grille.
Double the crap you can get.
Never Forget.Its funny that a post going off on the overly cautious covid crowd is supporting the "oh my god don't use a hi-lift, they're too dangerous!" crowd.
We're not being overly cautious, many of us here me included have just seen too many stupid dangerous situations some tried to use their Hi-Lifts in. RARELY is a Hi-Lift the best tool for the job or even appropriate. That's why I stopped carrying mine in 2003. It's certainly not needed for tire changing duties no matter how high the suspension lift is for 35's or even 37's in a pinch.Its funny that a post going off on the overly cautious covid crowd is supporting the "oh my god don't use a hi-lift, they're too dangerous!" crowd.
Back when I had the Samurai (and no winch) I used the hi-lift jack often, on bumper or rocker panel protection
In my strictly personal opinion 99.99999% of the Hi-Lifts carried externally by Jeep owners are nothing but display pieces saying 'look at me I are a offroader' when they don't know enough to know why it's very seldom the best or most appropriate tool.
This shows the "last straw" for me on Hi-Lift use after I broke a front axle shaft on Sledgehammer in Johnson Valley CA in 2003. I stupidly raised my TJ with my Hi-Lift from the side to pull the broken axle shaft out instead of just jacking the front axle up as everyone around me was advising me to do. I was shocked how far the Hi-Lift had teetered over while I was working on it. It had to be placed on top of that rock due to the trail being nothing but rocks there. At least I placed my tire underneath in case it did fall off. It was after this I stopped carrying my Hi-Lift.
a
You're right, you should never wheel on rocky trails like I prefer that are primarily moveable size rocks that can move around. Which is why and how I came to the conclusion 20 years ago that a Hi-Lift is not always or even usually the best tool for the job.I find hi-lifts useful at times (including similar situations as you showed in this pic) but I'm never going to set the base on a small rock like shown in that pic![]()
those damn things... first time I used a bumper jack, it dropped and whacked my shin as soon as the load was off it...
I’ve used one a handful of times on the trail but never needed one. I carried on for a year or two years ago but not in the last 10-15 years. But when there is a brake down someone on trail inevitably says “ I have a high lift jack” I’ll that help and sometimes it can be used for something other than it’s original intent. I Have made a winch point out of one once, used the bar to hold a shaft into a broken Dana 35 long enough to get a rig about 300 yards down a trail and out of the way, used one to raise the rear of a rig and then push it off the Jack to the side relocating the back end, and as a lever to roll a few boulders off a shelf road section of trail. That being said I still own a couple. And use them from time to tim on my property for pulling stumps or fence posts, moving farm implements ets.
just like a good hand cannon,. its better to have it and not need it, then to need it and not have it.
I would say not on the hood, that is an awful big piece of metal right in front of your head if you roll.
The other issue is thw weight will cause cracking on the hood eventually
