I am aware, and was only attempting to be humorous.![]()
The first couple of shots looked like miniatures at first glance. Wonderful collection! The dash on the Texaco tanker is reminiscent of - wait for it - a Tesla! All instrumentation in the middle. We've come full circle.
Started pulling my lower front control arm to install new ones, bolt and sleeve are rusted together…wife is bringing me sawzall blades from shopping trip….booooo
Previous owners be like "I don't trust shops so I did all the work myself!"
The work:
No nut son of a bitch
The work:
First off, the good stuff today. Worked on the TJ sun up to sun down, new bearings, new ball joints, 4.56 gear install, lunchbox, fun times!
The issue arose when I went to swap the u-joints in the front shafts at the end of the day. Those fools were seized, I don't know how they ever articulated in the vehicle outside of sheer force. Couldn't get the rings out to press out the joint, had to shatter them. Good joints don't look like this.
Turns out when the PO of this Jeep did joints last (or had them done) the ears on the drivers side shaft (Dana 30) were bent! Gonna have to leave the shafts out so I can at least drive the 3 miles to work in 2wd until my chromoly replacements get in Tuesday.
Nice work. Sounds like a good day.
Those were toast, wow.
In case you didn't know, you need the outer stubs to keep the unit bearing from coming apart when you drive it.
New to me Wrangle with 74k miles on it, and it was sitting in a garage for 3 years. Lots of work needs to be done.
The oil pressure gauge is pegged all the way to the right at 80, even at start up. This is very unlikely to be accurate. Any tips on how to fix this?
