Still fighting the battle of the suspension. This morning it was the left rear lower control arm. The axle end bolt took an hour or so to get out, then it was trying to pry the arm out of the brackets as the rubbers were all swollen up and stuck to them. Tomorrow morning it's going to be clean out the rust and rubber from inside the brackets, put the new arm in and then start on the other side. I did soak the heck out of the bolts with PB Blaster before I called a day, so maybe they won't be as much of a problem.
Once the suspension is done, it's going to be put new seals in the steering gearbox, then replace the muffle and tailpipe. All this stuff that I've put off for the past couple of years.
