Rock Sliders / Rocker Guards Guide
JMT
The Silver Fox 🦊
LAST EDIT: 9/25/2024
This is a compilation of my research for rock sliders. I hope it can serve as a guide to others who are looking for the best product for themselves, as well as an avenue for others to add updated data as this forum grows and products develop. This post has undergone several edits, especially after the comments and suggestions of @mrblaine. Thanks to him for his knowledge incorporated herein and under his own post later in the thread.
Rock sliders are an important armor component for protecting your tub between the front and rear fender. They come stock on the Rubicon, but those sliders are so minimal that if you touched the tub to a rock or tree you would likely damage your tub. If you plan to wheel in conditions that put your tub in danger, you may want to consider aftermarket rock sliders. These are different than nerf bars, which simply bolt to the frame and serve as a step for ingress/egress. IF that's all you want this guide will not be any help. If you're looking for rock sliders, keep reading.
Many considerations go into choosing the best rock sliders for your application. Are they mainly for looks? Are they required for function? A good driver can use them to pivot over rocks. Would you like a step to help get into the Jeep? Or that lady friend, wife? Does a step really help much? How much protection do you need underneath? Do they mount to the tub, the body mounts, or a combination? Tying into the body mounts can endanger and twist the frame. Do they provide an internal bracket that limits tub flex and deformation? Are you considering aftermarket flares? Or do you already have some? It may be best to purchase sliders from the same company that made your flares so everything ties in well. Or you may have the skills to fabricate a way to fit the different parts together. Does the mounting hardware leave a head extended or are they countersunk? Which is really better? Does it matter? An extended head near the lip of the tub could snap off if you hit a rock, but if tucked farther back would not pose a problem, and much stronger. The torque boxes are not a 90* bend from the lower tub edge, so how does the slider accommodate that difference? Is the edge a 90* angle that might dig into an obstacle and stop movement? Or does it have an angled edge designed to fit the tub and more easily slide over objects? And of course, what is your budget? How you answer these questions helps determine what is best for YOUR Jeep and YOUR use! Or, just get Fluxor and have the best of the best.
Below is a list of more well-known rock sliders available as of June 2023. If you find others I’ve missed or haven’t considered, and are worthy of being posted, please let me know and I’ll add to the list. If there are data points missing that you can fill in, please let me know. The sliders are divided into two classes; functional and non-functional. So, if you are looking for function, only the first few are really going to save your rig on the rocks! Some of them even require modification to provide needed protection
FUNCTIONAL
FluxOffroad Price $749.99 TJ/$824.99 LJ
Model: TJ/LJ
Warranty: N/A
Manufacturing: 3/16” 6061 Aluminum/3/16" Steel
Step: No
Mounting: Side and bottom of the tub, countersunk on all visible hardware with recessed Hex in the bottom side rear portion of the torque box.
Finish: Raw
Weight: unknown
Aluminum Rock slider Kit. Double bends on the lower side of the tub creating more strength and an angled surface to help slide off obstacles. Kit includes both passenger and driver side 3/16" 6061 T6 Aluminum Rocker Base Plate, 3/16" P.O. Steel Rash Guard, .5" Thick Aluminum Inner Tub Braces and M8 Torx SS Countersunk Hardware. Drilling and Rivet Nut Tool Required. ww2ww. Best of the best.
DM @Fluxor
Savvy Rocker Steel Slider ($719)
Model: TJ
Warranty:
Manufacturing: Aluminum base.
Step: Yes, replaceable
Mounting: Nutserts, reinforced backing plates, all stainless steel
Finish: Raw
Weight: ~69lbs
The design incorporates a 45* angle around the edge of the tub. This is far superior to the 90* angle on most rock sliders. It incorporates a two-piece design, the slider and the step, so that if one part is damaged, the whole does not need to be replaced, only one piece. They also have an interior backing plate, making them much stonger than most sliders. This is a great option for someone who will be on the rocks. It provides wheel well to wheel well coverage.
https://savvyoffroad.com/product/rkr-kit/
Genright Mini Boat Side Rocker Guards w/Bars ($899-939) Aluminum Version not for Rocks ($1398)
Model: TJ, YJ or CJ-7
Warranty:
Manufacturing: Laser Cut and CNC Formed from 3/16” steel. Optional backing plate
Step: Yes, with dimple die step plate for traction entering and exiting (4 ½” wide). Side bar is 1 ½” x 0.120 thick DOM tube (angled 15* upward)
Mounting: Side of tub and underneath tub. Bolt heads are countersunk on both for a smooth sliding surface. ww2ww.
Finish: Bare metal.
Weight: ~81 lbs
The design incorporates an angle at the edge of the tub. They offer an optional interior support bracket, which will mean that your tub will not bend outward when someone uses the step. ww2ww. May require some trimming. Requires modifications to improve.
https://genright.com/products/mini-boat-side-rocker-guards-w-bars-tj-yj-cj.html
Aluminum version
https://genright.com/products/aluminum-mini-boat-side-rocker-guards-w-bars-lj-tj-yj-cj.html
https://genright.com/products/tj-yj-cj-mini-boat-side-rocker-guards-w-bars-steel.html
Warn ($500)
Model: TJ, LJ, YJ, CJ7
Warranty:
Manufacturing: 3/16” Steel
Step: No
Mounting: Side of tub not countersunk and underneath, but unclear how
Finish: Black Powder Coat
Weight: unknown
This slider has a rounded edge as it wraps around the tub, making it a functional slider. See post #74 on page 4 of this thread for pictures. Not ww2ww. There have been complaints about the slider warping, so, if your going to be playing hard in the rocks, avoid.
https://wranglertjforum.com/threads/warn-slider-body-bowing.30626/post-493480
https://www.warn.com/truck-suv-mounting-protection-body-armor
JCR Rock Sliders Crusader ($692)
Model: TJ, LJ, YJ
Warranty:
Manufacturing: CNC cut and formed from 3/16” steel
Step: Yes, (3 ½” wide)
Mounting: Side of tub and bracket inside tying in to the seat mount locations.
Finish: Bare metal or Black Powder Coat (+ $150)
Weight: 92 lbs for the pair
This mini boat slider has a unique look and claims to provide higher ground clearance than traditional angle steel tube sliders, but that is no true relative to the sliders listed above. Has built in Hi-Lift jacking points front and rear. Has ann interior tub support that ties into the front seat. Made in the USA. Bolts through the torque box into the floor of the tub which is dumb. Modify by using 7-8 nutserts in the torque boxes. The spacer for the rear torque boxes is not high enough. Add an additional 3/16" spacer before installing. Use the provided internal spacer that you ditched for nutserts. Add an additional nutsert near the Jeep emblem on your tub to hold the tub flush against the slider. Requires additional modifications to make it better. The boatside step is not ww2ww, only the backing plate.
https://www.jcroffroad.com/product/SWBSL-CR.html
NON-FUNCTIONAL
Barnes 4x4
Model: TJ
Warranty: ?
Manufacturing: 3/16” Steel Plate
Step: No
Mounting: side of tub, countersunk. Underneath, ties into body mounts
Finish: Raw
Weight: ?
Very cost friendly. These sliders are ww2ww. Give minimal undercarriage support. Tie into body mounts that could cause undue stress.
https://barnes4wd.com/products/tj-rocker-guards
ARB ($585)
Model: Short Wheelbase TJ’s only
Warranty: Two years materials and workmanship
Manufacturing: Tough, 1.25 diameter schedule 40 tubular steel
Step: Yes (@30* upward from tub) or no
Mounting: Side and underneath tub. Internal mounting bracket.
Finish: Powder Coat Black
Weight: 63.5 lbs for the pair. Sounds dubious, but if they really are only 1/8" thick, then that possibly explains the relative light weight.
ARB has a long-standing reputation in the Jeeping community for making great products. However, this slider has been criticized for being only 1/8" steel in some places. It has resulted in severe damage (See post #278 on page 14 of this thread). The internal bracket is supposed to eliminate body roll when pressure is exerted on step. Has a double bend. They are not ww2ww.
https://arbusa.com/jeep-wrangler-tj-1997-2006/bumpers-protection-equipment/side-rails-steps/
Poison Spyder Rocker Knockers with Sliders ($375-415)
Model: TJ, LJ, YJ or CJ-7
Warranty:
Manufacturing: Laser Cut and CNC Formed from 3/16” plate steel.
Step: Yes, DOM tube
Mounting: Side of tub countersunk and underneath tub at the body mounts and ribs, etc…for smooth sliding surface, but not needed
Finish: Bare Steel
Weight: 70lbs
Poison Spyder has a good reputation. This rock slider is popular, but not a good choice because they tie into the body mounts which could create undue stress. Good price point. Works with a body lift without a resulting gap or misalignment.
https://shop.poisonspyder.com/TJ-Rocker-Knockers-with-Sliders-p/14-08-060.htm
Motobilt ($275 no step/$475 step)
Model: TJ
Warranty:
Manufacturing: 3/16” steel plate
Step: Optional, also offer Standard length or Notched for Motobilt fenders.
Mounting: Side of tub countersunk and underneath attached to body mounts
Finish: Bare steel
Weight: unknown
Cost friendly. Made in the USA. Minimal underbody protection. Tie into body mounts that could cause undue stress.
No step
https://www.motobilt.com/jeep-tj-rocker-guards-with-stock-flares.html
Step
https://motobilt.com/products/jeep-tj-full-length-rocker-guards-w-step-97-06-wrangler-tj-bare-steel
C&C Fabrication ($450-563)
Model: TJ, LJ
Warranty:
Step: Yes, 1 ¾” x 0.120 DOM with nice plate for step.
Mounting: Side of tub. Underneath NO MOUNTING BOLTS, 2" lip underneath the edge.
Backing Plates: No
Finish: Bare metal
Weight: ~40 lbs. This is what I was told over the phone, seems incorrect though.
Minimal underbody protection. Hard to tell much from the pics online. Not mass produced. Allow 7-10 days for build and 3-5 days for shipping. They have several options, including a DIY version. One option for ww2ww with their fenders. Another that is not ww2ww.
http://shop.ccfabs.com/Rock-Sliders_c8.htm
Rugged Ridge ($314)
Model: 04-06 TJ
Warranty: 5 year limited
Step: Yes (integrated 4"). 2” on some applications (?)
Mounting: Side of tub. Bolt heads are not flush. Underneath unclear
Finish: Tough Black Texture
Weight: 68lbs for the pair
Cost friendly, works with most aftermarket flares, has cut outs for use of a Hi-Lift jack, includes rubber welting to protect the paint and body. However, the welting could permit the slider to move which would be a con. No internal brace (you can fab one). Bolts up through the torque boxes and through the floorboard (discouraged). Better to use nutserts into the torque boxes.
https://ruggedridge.com/p/xhd-rock-sliders/
Warrior Rock Sliders ($405)
Model: TJ
Warranty: 180 days materials and workmanship
Manufacturing: 3/16” plate steel
Step: Yes, tapers from front to rear, or no.
Mounting: Side of tub. Underneath unclear
Weight: Unknown
Warrior Rock Sliders provide 6-7 inches of protect under the tub.
https://warriorproducts.com/jeep-tj-rock-sliders-90990.html
Rock Hard 4x4 ($449-499)
Model: TJ
Warranty: Lifetime
Manufacturing: Laser Cut 3/16” steel
Step: Yes or no. 1 ¾” x 0.120 DOM
Mounting: Side of tub countersunk and underneath countersunk for a smooth sliding surface, but not necessary
Backing Plates: No
Finish: Black Powder Coat Semi-Gloss 20% Texture
Weight: 60 lbs
Rock hard is 100% made in the USA, not the 75% legal standard. There is no welding or cutting required and can be used with 99% of flares and all body lifts. Since black powder coat is included, this is another slider that is hard to beat at that price point. Not ww2ww. They boast about it. LOL.
No step
https://www.rockhard4x4.com/product_p/rh-3001-c.htm
Step
https://www.rockhard4x4.com/product_p/rh-3001-sc.htm
Metalcloak Rocker Rails ($559)
Model: TJ
Warranty:
Manufacturing: 7GA hot rolled steel plate
Step: Yes, 1 ½” x 0.120 steel tubing
Mounting: Side of tub in two linear paths, one above the step and one below.
Finish: Raw steel or Black Powder Coat (+ $159)
Weight: 94 lbs for the pair
Metalcloak makes decent stuff and is known for good customer service. These rockers have a deflector plate, high lift mount location, and are designed to integrate with the MC fenders, but can be used without them. There are two versions, make sure you get the right version for your rig.
https://www.metalcloak.com/Rocker-Rail-Pair-TJ-p/2312.htm
Cav Fabs ($250)
Model: TJ
Warranty:
Step: No
Mounting: Side of tub countersunk and underneath not countersunk.
Backing Plates: No
Finish: Raw steel
Weight: 64lbs
These rock guards claim to tie into the body mounts for extra stability, but they also claim to notch around that area, so it is unclear. They have countersunk holes, which is not necessary. Only 4 mounting locations underneath, so you’d need to add several more. Do not appear to be ww2ww. Do have a slight double bend as the outer tub wraps under toward the torque boxes.
https://cavfab.com/products/tj-rocker-guards
TNT Customs Standard Rocker ($500-875)
Model: TJ
Warranty:
Manufacturing: CNC cut and formed 3/16” steel plate
Step: Yes or no. Step is 3.5" wide
Mounting: Side of tub and underneath, neither countersunk. Explanation from TNT is that it weakens the steel at that point. They have never had a bolt head damaged to the point it could not be removed. Optional internal brace ($150).
Finish: Bare steel
Weight: 72 lbs
TNT Customs rock sliders look pretty beefy. Gives full underbody coverage and is body lift compatible. There is a double angle as the slider comes around the edge of the tub. It is not as demarcated as the Savvy and Genright's below, but is superior to the previous rock sliders in this list. ww2ww. Fits with their flares. A decent option for someone looking for something that is pretty good.
https://tntcustoms.com/product-category/jeep-tj/rock-sliders-jeep-tj/
Apologies for leaving others off like UCF, Nemesis, Smittybilt, Ace Engineering, et. Al., as well as some of the alternate versions specific to your TJ or LJ, flare set up, etc...However, I hope this helps folks find what’s out there and make an informed decision. My personal opinion of the best overall sliders in order are; Savvy, Genright, JCR, Cav Fabs, TNT, and Warn. Hope to see you on the trails!
Rock Sliders/Rocker Guards
Rock sliders are an important armor component for protecting your tub between the front and rear fender. They come stock on the Rubicon, but if you wheel on another model in conditions that put your tub in danger, you may want to consider aftermarket rock sliders. Even if you have a Rubicon, you may want a beefier slider for your style of wheelin’. We're not talking nerf bars here, but if you want nerf bars, you might consider reading up on rock sliders, as they may be a better mod for you if you wheel!
Many considerations go into choosing the best rock sliders for your application. Are they mainly for style? Or are they required for function? A good driver can use them to pivot over rocks. Would you like a step to help get into the Jeep? Or that lady friend, wife? How much protection do you want underneath? Do you want to protect your body mounts? Or just the edge and side of the tub? How do they mount to your Jeep? Do they mount only to the side of the tub or also underneath? Do they tie into the body mount? Or use an internal bracket that utilizes the seat mounting hardware? Are you considering aftermarket flares? Or do you already have some? It may be best purchase sliders from the same company that made your flares so everything ties in well. Does the mounting hardware leave a head extended or are they countersunk? An extended head underneath could snap off if you hit a rock. And of course, what is your budget? These and other questions are part of determining what might be best for YOUR Jeep!
Below is a list of rock sliders available as of January 2018. Hopefully this bit of research will help in your search. If you find any others I’ve missed or haven’t considered, and are worthy of being posted, please let me know and I’ll add to the list. If there's data you have to fill in, also, let me know. They are in no particular order, but I've saved some of the best for last, so hang on!
ARB ($466-492)
Manufacturing: Tough, 1.25 diamter schedule 40 tubular steel
Mounting: Side of tub. Underneath ties into body mounts giving about 7 inches of protection underneath.
Weight: Unknown
ARB has a long-standing reputation in the Jeeping community for making great products. This slider is no exception.
http://store.arbusa.com/ARB-Rock-Sliders-With-Steps-For-Jeep-TJ-2-Door-Model-4450010-P3391.aspx
Rugged Ridge ($299-399)
Model: 04-06 TJ
Step: Yes (2” wide)
http://www.ruggedridge.com/heavy-du...-11504-15.html#product_tabs_additional_tabbed
Genright Mini Boat Side Rocker Guards w/Bars ($599)
Warranty:
Manufacturing: Laser Cut and CNC Formed from 3/16” cold rolled steel. Side bar is 1 ¾” x 0.120 thick DOM tube (angled 15* upward)
Mounting: Side of tub and underneath tub. Bolt heads are countersunk for smooth surface
Finish: Bare metal
Weight: Unknown
Genright makes a very solid rock slider. May require some trimming.
Genright Standard Rocker Guards w/Bars ($399)
Warranty:
Weight: Unknown
https://genright.com/products/tj-yj-cj-standard-rocker-guards-w-bars-steel.html
Warranty:
Step: Yes, DOM tube
Finish: Bare Steel
Weight: Unknown
Poison Spyder makes good stuff, and this rock slider is no exception, and at a price point that is hard to beat. Works with a body lift without a resulting gap or misalignment.
Warrior Rock Sliders ($)
Model: TJ
Weight: Unknown
http://www.warriorproducts.com/cata...-06-jeep-wrangler-tj/side-steps/rock-sliders/
Metalcloak Rocker Rails ($399)
Model: TJ
Warranty:
Finish: Bar metal or Black Powder Coat (+ $124)
Metalcloak makes good stuff and is known for good customer service. These rockers have a deflector plate, high lift mount, and are designed to integrate with the MC fenders, but can be used without them.
JCR Rock Sliders Crusader ($459+)
Model: TJ, LJ, YJ
Warranty:
JCR makes solid stuff for our Jeeps. This mini boat slider has a unique look and claims to provide higher ground clearance than traditional angle steel tube sliders. Has built in Hi-Lift jacking points front and rear. Made in the USA.
Rokmen Mercenary ($399)
Model: TJ, LJ, YJ
Warranty:
Manufacturing: Precision Laser Cut and CNC form bent from 3/16” steel plate
Step: Yes, slider is 1 ¾” DOM Tubing
Mounting: Side of tub countersunk stainless steel. Bottom of tub countersunk alloy for smooth sliding surface
Finish: Bare metal
Weight: Unknown
Will work with all body lifts and gives full underbody protection, fully TIG welded and all grade 8 hardware. Welds are hard to beat. This is a very good slider at a very good price. Very hard to beat!
C&C Fabrication ($225-328)
Model: TJ, LJ
Warranty:
Mounting: Side of tub. Underneath unsure
Finish: Bare metal
Weight: Unknown
C&C Fabrication looks like they make solid stuff. Hard to tell a lot, but these are not mass produced, allow 7-10 days for build and 3-5 days for shipping. They have several alternate options, including a DIY version for $225.
Rock Hard 4x4 ($300-340)
Model: TJ
Warranty: Lifetime
Weight: Unknown
Rock hard is 100% made in the USA, not the 75% legal standard. There is no welding or cutting required and can be used with 99% of flares and all body lifts. Since black powder coat is included, this is another slider that is hard to beat at that price point…
http://www.rockhard4x4.com/product_p/rh-3001-sc.htm
TNT Customs ($270-350)
Model: TJ
Warranty:
Step: Yes or no. Step is very nice.
Finish: Bare steel
Weight: unknown
https://www.tntcustoms.com/jeep_parts/tj_rock_sliders_97_06_wrangler_tj_tnt_customs
Warn ($329)
Warranty:
Step: No
Weight: unknown
Warn is a well-known and reputable company, mostly for their M8000 winch.
https://www.warn.com/truck/mounting-systems/rock_sliders.jsp
Motobilt ($275)
Model: TJ
Warranty:
Step: No
Finish: Bare steel
Weight: unknown
Motobilt is making some interesting products in the Jeep world. These look solid and at a good price point. If I didn’t want a step and I was on a budget, I’d buy these hands down. Made in the USA.
Savvy Rocker Steel Slider ($559)
Model: TJ
Warranty:
Finish: Raw
Weight: unknown
Savvy, the name says it all.
http://shop.savvyoffroad.com/Savvy-Jeep-Wrangler-TJ-Rockers-w-Step-Sliders-1997-2006-RKR-Kit.htm
Nemesis Billy Rocker ($649)
Model: TJ
Warranty:
Step: Yes, flat with lip
Mounting: Countersunk on sides, underneath it completely covers the body mounts and goes all the way to the frame providing total protection.
Finish: Bare, Semi-Gloss or Textured Powder Coat (+$200)
Weight: 55 lbs for the pair
Nemesis has made a killer product here. This is the ultimate rock slider as far as I can tell. The entire side of the Jeep lower tub is protected and even the body mounts are completely covered. They are aluminum to boot, so just 27.5 lbs per side will be added to your Jeep. It doesn’t come without a price tag though! You get what you pay for.
https://www.nem-ind.com/products/jeep-wrangler-tj-accessories/97-06-tj-billy-rocker.html?___SID=U
I apologize for leaving others off by Smittybilt, Ace Engineering, et. Al., but I simply got tired of doing all this research. However, I hope this helps folks find what’s out there and make an informed decision. As for myself, I still can’t decide, but the top contenders are Nemesis, Rokmen Mercenary, Rock Hard 4x4, Poison Spyder and Metalcloak (because I may end up getting their fenders and flares one day). I'm sure I'll be happy with any of these. See you on the trails!
Metalcloak sells two rocker guards, its very important if you ever plan to run the fenders to get their fender specific version :).
Nice work!
Nicely done. Must have had some time away from the little JMTs :D Personally I like the PS/GR style since they do not rob any ground clearance. I'd pass on the extra $$ for powder coating since they are likely to get beat up and need repainting anyway.
Damn @JMT, great job on this. I've been meaning to do something like this for a while, you just beat me to it!
While you may have left some of the others out, I personally think you covered all the high end rock sliders / rocker guards, so kudos to you!
Wow! Great write-up!
I'm planning on going with the Warn sliders. I haven't found many pictures or reviews of them. If anyone has them, please share!
Regarding this: "Would you like a step to help get into the Jeep?"
My last TJ had a modest lift and anyone over 5'8" could step up and in. The step on my slider was actually a hindrance of doing so. So with my next purchase I'll be seeking something without a step. I also imagine this makes them lighter, but am open to correction.
I've also read that people favor tub mounted over body mounted, but I'm not sure why this is.
I'm sure Starrs can weight one of his :)
If the figures that people are quoting are correct, Savvy (the weight of the shipped sliders with step was 84lbs) actually weight more than the ARB's.
Is this correct, Guys can we clarify this?
No way the ARB is 63.5lb for the pair.
I got that figure from @Starrs, who had it quoted to him on the phone. I also thought that it would be above 90lbs, because all the 3/16” steel sliders are 90+lbs. The Savvy’s appear to be in the 80-84 range, since they’re a hybrid of steel and aluminum. Only ones that I found that were entirely aluminum were the Nemesis, and they weigh in at 55 lbs for the pair, amazingly lightweight.
I have a warn front stubby bumper, and the powder coating was horrible; I am assuming bad metal prep before the coating. I actually had to strip it all down to metal and then I primerred and painted it. I could have sent it back, but customer service was pussy-footing around, so I just fixed it myself. Other than the crappy powder coat the bumper is solid which made it worth while to repaint, but be aware that you may have issues with the powder coat. I would ask Warn to see if you can get them bare metal in the first place. It is much easier to paint bare metal than stripping crappy powder coating.
Reactions: cjaama and JMT
....well that's interesting.:icon_popcorn:
That definitely gives me pause in my consideration, and makes me want to lean toward ARB, not to mention the design is AEV. Great hard data!
