Any aren't the hardtop nuts wing nuts or thumb screws?
Because you can’t install a thumbscrew with a machine and that allows for error in the process- A proper torque value can be built into the equipment used with a traditional fastener.
Reactions: suicideking
Reactions: AndyG
Reactions: sab
They do - there’s just only so much variation a manufacture is going to go for-
Plus you have to be able to perform the task without damage to the vehicle and in a certain time frame- At least that’s my theory😆
Having worked alongside the manufacturing engineers as a design engineer, the mfg engineers are pretty darn creative, and usually don't complain (much) about the crazy stuff we design engineers come up with. It's the bean-counters that stop stuff like that. Darn bean-counters!
I would add 'for safety'.
Anything that is designed to come apart easily will.
A thumb screw can be bumped by cargo or loosened by a kid.
Next thing you know...
Reactions: AndyG
Very good. Have you guys ever wondered if they ever considered nutserts for them ..I realize you need some movement for adjustment boy those things can be aggravating , specially up around the rollbar.
Reactions: SPECWAR
If you're referring to the nuts being aggravating, I attached mine under the rail with silicon adhesive.
Reactions: inkedrose and AndyG
