New update.
Adjusted the tc cable as far “out” as it will go. If anything, it’s worse. Kickdowns were hard to get after like 30mph. I also may need to readjust the kickdown band. ASGM manual said to back off the screw 2.5 turns, FSM says 2.25 turns. But I’ve been advised to readjust it anyway after a little bit of driving. Will do that tonight & drive some more.
Temp wise, it was only about 90 when I took it out this morning. Ran around 180 for a while, but then kicked up to around 200 once I got back in the neighborhood. Pulled into the driveway and put it into park and it instantly shot up to 214 and climbed to 218, and then held steady. Held steady in N as well, expected it to drop but I guess engine temp will affect it as it’s flowing through the radiator.
Turned it off, the to ON so I could see the gauge. It started dropping with the engine off, but in P there is just as much fluid flowing as with it off, so I guess the exhaust must be transferring heat in? Either way, I swear it’s running hotter than it used to.
