Anybody tried these? Although my seats don’t wobble all the bushings are missing.
https://www.amazon.com/dp/B08D72MQB7/?tag=wranglerorg-20
I have used these, and they work perfectly.
That's great! I couldn't find the good reviews when I did a quick look.FWIW these have 7 ratings for 4.1 stars total
The Stable Seat guy is all over the TJ pages on FB. Several have reported issues with breakage and premature failure. Like you, I suspected that manufacturing method would be less that optimal for this application but for a long time no one said much negative and then the reports of failure started showing up.After a pretty exhaustive search, the forum consensus is that "Stable Seat" on Etsy is a good alternative. Although they are 3D printed, which is still not great, no one has had anything bad to say about them.
That being said, I have used 3D printed parts in the past in my Jeep and internal temps can sometimes creep into the yield temp of the plastic and they will deform into a goopy state and retail that when cooled. Also ABS and PLA do not hold up well to friction very well, and PLA hates water. Neither are great for this app, but if they are Nylon then it may hold up well to the wear, but again it doesn't like water.
There have been a few who make these bushing themselves out of Delrin (I think this is the way to go in the case of homebrew), but you would need access to a lathe or machine shop to do that. (driving up cost)
One guy found a flanged bushing/washer thing at Ace hardware that worked after minor tweaking, link provided below.
https://wranglertjforum.com/threads/seat-noise.9145/
My final opinion is go with Stable Seat as it is a proven brand and there haven't been any bad reviews that I could find. The amazon link above only has one review and its poor.
https://wranglertjforum.com/threads/product-review-stable-seat.11070/
I thought that was going to happen. A lot of the posts were from 2 ish years ago. About the time that ABS would give way, even with minimal use. 3D printing is great for prototyping, but it should rarely be used as an end user material.Like you, I suspected that manufacturing method would be less that optimal for this application but for a long time no one said much negative and then the reports of failure started showing up.
I have a 3D printed part that has enough plastic in it to make a couple of hundred seat bushings and it never once occurred to me that it would make an actual viable part. For awhile reading everyone raving about how good the bushing kits were, I just figured I wasn't keeping up with 3D printing in plastic and needed to pay more attention. Then the failures started.I thought that was going to happen. A lot of the posts were from 2 ish years ago. About the time that ABS would give way, even with minimal use. 3D printing is great for prototyping, but it should rarely be used as an end user material.
It’s the same shitor one could order these like I did and save
https://www.amazon.com/gp/product/B08D72MQB7/?tag=wranglerorg-20
Won’t work for mine anyway, I have an 02 and apparently those only work for 03-06. But all the comments say it’s basically the same 3D printed crap, nor are they even available, so…..not really.....but go ahead
